Euro Car Parts
I'm just ordering some stuff from ECP and just look at the list of items excluded from this promo!!!
Induction Kit
Performance Air Filter
Shock Absorber Kit
Lowering Kit
Anti-roll Bar Stabiliser Kit
Performance Brake Disc
Performance Brake Pad Set
Air Filter Element
Sports Clutch Kit
Big Brake Kit
Brake Hose Kit
K&N Oil Filter
Locking Wheel Kits
Performance Downpipe & Manifold
Performance Lighting
Performance Bushes
Per Suspension Kit
Silicon Hoses
Suspension Kit
Wheel Spacers
Performance Shock Absorber
Dump Valve
Adjustable Sus Arm
ECU Remap Tool
Fog Lamp Bulb
HID Kit
Stop Tail Lamp Bulb
Style Corner, Indictor Lamp
Style Headlamp
Style Rear Lamp
Performance Exhaust System
Coilover Kit
1" Drive Deep Impact Socket
1" Drive Impact Sockets
1/2" Couplings
1/2" Drive Deep Impact Sockets
1/2" Drive Impact Sockets
3/4" Drive Deep Impact Sockets
3/4" Drive Impact Sockets
3/8" Drive Deep Impact Sockets
3/8" Drive Impact Sockets
Accessories
Adaptor Couplings
Air Hammers
Air Hose (Retracting)
Air Hose
Air Line Fittings
Air Ring Main System
Air Tool Kits
Angle Grinders
Blow Guns
Buffing & Punching
Die Grinders
Drills
Engraving
Extension Bars
Filters & Regulators
Impact Extension Bars
Impact Socket Adaptors
Impact Wrenches
Key Sets
Nails
Oil
Polisher Consumables
Polishers
Ratchet Wrenches
Riveting
Sander Consumables
Sanders
Saws & Cutting
Saws & Cutting Accessories
Scalers
Screwdrivers
Socket Sets
Socket Sets
Staplers & Nailers
Staples
Universal Joints
Accessories
Belt Driven
Compressor Oil
Direct
Engine Driven
Screw Compressors
Specialist
Air Brushes
Air Kits & Accessories
Cleaning Tanks
Cutters
Dust Free
High Pressure Spray Guns
HVLP Spray Guns
LVLP Spray Guns
Masking Products
Panel & Trim Tools
Panel Dryers
Panel Stands
Sealant Guns
Sheet Tool Accessories
Spray Gun Accessories
Spray Gun Consumables
Spray Guns
Vehicle Stands
Body Repair Tools
Chassis Straighteners
Clamps & Measuring
Arc Welders
Inverter Accessories
Inverters
MIG Accessories
MIG Consumables
MIG Welders
Oxyacetylene
Oxyacetylene Consumables
Plasma Cutters
Plasma Inverters
Spot Welder
Stud Welder
Welding Accessories
Welding Consumables
Cable Shears
Detectors & Measuring
Hole-Saws
Levels
Measuring & Comparison
Miscellaneous
Pipe Products
Staplers & Nailers
Testers
Tiling
Wrenches
Punches & Chisels
Thread Cutting Tools
Workshop Tools
Brushes
Craft
Cutters
Cutters
Driver Bit Sets
Extractors
Files
Hacksaws
Hammers
Hammers
Levels
Locking Pliers
Mallets
Miscellaneous
Multi Tools
Nylon Faced Hammers
Pliers
Pouches
Precision Tools
Precision Tools
Pry Bars
Punches & Chisels
Punches & Chisels
Saws
Saws
Screwdriver Bit Sets
Screwdriver Sets
Screwdrivers
Screwdrivers
Tie Downs
Workshop Tools
Wrench Sets
Accessories
Consumables
Engine Cleaning
File Sets
Mechanics Mats
MOT
Pliers
Prybars
Scrapers
Tap & Die Sets
Tool Kits
Tweezers
Wing Covers
Air Jacks
Axle Stands
Bottle Jacks
Crane Accessories
Engine Stands
Engine Supports
Farm Jacks
Fixed Cranes
Folding Cranes
Jack Accessories
Jacking Beams
Motorcycle Lifts
Motorcycle Stands
Other Lifts
Ramps & Chocks
Scissor Jacks
Transmission Jacks
Trolley Jacks
Wheel Removal Trolleys
Beam Clamps & Trolleys
Chain Blocks & Hoists
Drum Trolleys
Folding Trucks
Lifting
Pallet Trucks
Platform Trucks
Sack Trucks
Workshop Trolleys
Amber Beacons
Booster Cables
Electric Winches
Hand Winches
Mobile Power Systems
Surge Protection
Tie Downs
Towing Accessories
Towing Aids
Trailer Accessories
Trailers
Accessories
Grinders
Grinding Discs
Sanders
Wire Brushes
Drill & Bit Sets
Pillar Drills
Consumables
Cut-Off
Hacksaws
Drill Vices
Engineering Vices
Mitre Clamps
Vices
Riveters
Shears
Battery Maintenance
Crimping & Stripping
Multimeters
Ni Fe
Arc Welders
1" Drive Socket Sets
1/2" Drive Deep Sockets
1/2" Drive Extension Bars
1/2" Drive Socket Sets
1/2" Drive Sockets
1/4" Drive Deep Sockets
1/4" Drive Extension Bars
1/4" Drive Socket Sets
1/4" Drive Sockets
3/4" Drive Extension Bars
3/4" Drive Socket Sets
3/4" Drive Sockets
3/8" Drive Deep Socket Sets
3/8" Drive Deep Sockets
3/8" Drive Extension Bars
3/8" Drive Socket Sets
3/8" Drive Sockets
Accessories
Allen Keys & Sets
Driver Bit Sets
Extension Bars
Mixed Socket Sets
Adaptors
Ribe Sets
Socket Sets
Spline Sets
TRX, Spline & Hex
TRX-Star Sets
Torque Screwdriver
Torque Wrenches
Adjustable Wrenches
Bit Driver Sets
Breaker Bars
Combination Wrenches
Crows Foot Wrenches
Flare Nut Wrenches
Flex Head Wrenches
Ni Fe
Nut Drivers
Ratchet Wrenches
Wrench Sets
Batteries & Chargers
Cordless Screwdrivers
Drills
Impact Wrenches
Polishers
Screwdrivers
Circular Saws
Drills
Grinders
Hot Air Gun
Jig Saws
Multi Tools
Polishers
Accessories
Backing Pads
Battery Chargers
Battery Chargers
Battery Chargers
Compounding Heads
Cutting Discs
Drill & Bit Sets
Drill Chucks & Keys
Flap Discs
Grinding Discs
Wire Brushes
Accessories
Removal Tools
Soldering Guns
Soldering Irons
Soldering Torches
Air Conditioning Tools
Leak Detection Kits
Accessories
Battery Service Tools
Fuses
Testers
Headlamp Beam Setters
Laser Alignment Devices
Brake Bleeders
Brake System Tools
Cylinder Hones
Hose Pinch Tools
Anti Freeze Testers
Cooling System Tools
Hose Clamps
Leak Detection Kits
Water Pump Pliers
Analysis Tools
Diagnostic
Test Probes
Timing Lights
Compression
Cylinder Leakage
Fuel Pressure
Oil Pressure
Vacuum & Fuel
1/2" Drive Head bolt kit
Cam & Valve Tools
Clutch Tools
Diagnostic
Exhaust Tools
Fan Tools
Fuel & Injection Tools
Hose Tools
Hub Spanners
ID Tags & Clips
Pliers
Plug & Piston Tools
Pressure Testing
Pulley Removal Tools
Punch Sets
Spring Compressors
Stands
Stethoscope
Thermometers
Throttle Tools
Timing Belt Tools
Torque Gauges
VAG Tools
Wrenches
Accessories
Ball Joint Tools
Bearing removal Tools
Bearing Tools
Bush Removal Tools
Coil Spring Compressors
CV Joint Tools
Ford Tools
Hub Tools
Shock Absorber Tools
Drain Plug Keys
Oil Filter Crushers
Oil Filter Sockets
Oil Filter Wrenches
Gear Pullers
Slide Hammers
Alfa Tools
BMW Tools
Camshaft Tools
Chrysler Tools
Citroen Tools
Crank Tools
Diesel Engine Tools
Fiat Tools
Flywheel Positioning Tools
Ford Tools
GM Tools
Honda Tools
Land Rover Tools
Petrol Engine Tools
PSA Tools
Renault Tools
Rover MG Tools
Setting Kits
VAG Tools
Imapct Sockets
Specialised Socket Sets
Spline Keys
Star Keys
Thread & Bearing Tools
Air Knife
Door Hinge Pin Tools
Interior Tools
Moulding Release Tool
Panel Removal Tools
Trim Tools
Windscreen Tools
Air Line Gauges
Alignment Tools
Pressure Gauges
Pumps
Tyre Changers
Tyre Inflaters
Tyre Inflators
Wheel & Tyre Tools
Car Covers
Cleaning Aids
Accessories
Vacuum Cleaners
Pro Vacuum Cleaner
Upholstery Cleaner
Valeting Machines
Cable Ties
Seat Covers
Staplers & Nailers
Air Presses
Arbor Presses
Battery Chargers
Battery Chargers
Battery Chargers
Battery Maintenance
Cleaning Tanks
Creepers
Fuses
Hydraulic Presses
Metal Benders
Pipe Benders
Seats
Shot Blasting Cabinets
Shot Blasting Consumables
Shot Blasting Guns
Solar Panels
Starters & Chargers
Tool Rails
110V Lead Lamps
12V Lead Lamps
230V Lead Lamps
Accessories
Batteries
Bulbs
Cable Reels
Extension Leads & Plugs
Flexi Lights
Floodlight Accessories
Floodlights
Generators
Inverters
Lanterns
Lead Lamp Accessories
LED Lead Lamps
Lighting
Magnetic Lights
Retractable Lead Lamps
Spotlights
Tool Transformers
Torches
Work Lights
Barrel Bunds
Diesel Transfer Pumps
Drain Pans
Drainers
Emergency Kits
Fluid Transfer Pumps
Fuel Cans
Fuel Cans
Funnels
Grease Guns
Measuring Jugs
Oil Cans
Oil Drainers
Spill Mats
Water Container
Domestic Pressure Washer
Engine Driven
Hot Water Pessure Washer
Pressure Washer Accessories
Pro Pressure Washer
Steam Cleaner
Submersible Pumps
Suction Hoses
Surface Mounted Pumps
Water Pump
Body Protection
Ear & Head Protection
Eye & Face Protection
Fire Protection
First Aid
Hand Protection
Respiratory Protection
Workwear
Alarms
Barriers & Wheel Clamps
Cash Boxes
Key Cabinets
Lockers
Padlocks
Safes
Storage Cabinets
Middle Boxes
Mobile Workstations
Parts Storage
Plastic Toolboxes
Racking
Rollercabs
Tool Bags
Tool Cabinets
Tool Cases
Tool Chest Accessories
Tool Chests
Tool Storage Panels
Tool Trays
Toolboxes
Top Chests
Workshop Trolleys
Bins
Blowers
Brooms & Squeegee
Cycle Products
Dehumidifiers
Desk & Tower Fans
Drainage
Dust Extractors
Electric Heaters
High Velocity Fans
Hose Accessories
Infared Heaters
Kick-Steps
Ladders
Matting
Paraffin/ Diesel Heaters
Platform Ladders
Propane Heaters
Safety Steps
Step Stool
Tarpaulins
Ventilators
Water Hose
Vices
Accident Recorder
Fuel Injector
Fuel Injector
Injector
Throttle Body
Fuel Pump
Diesel Pumps
Turbo
I always check promo codes before ordering from ECP and always save money on the listed price
