Errors 95AB and 98D3 that won't clear.
Magicarcher
 Warwickshire
Getting a couple of SRS errors that won't clear:
  • 0095AB SBSR Control Unit Fault (which I believe could be bing caused by the one below)
  • 0098D3 SBSR Short Circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, to ground
Does anyone know if the second is referring to the steering wheel airbag or the door airbag? and hence is the control unit refered to the Main SRS ECU on the transmission tunnel or the satelite ECU on the LHS B post behind the seat?
