Many thanks for the reply. Initially putting in a different motor because there are no fault lights or fault codes with the original, going to see if that solves the problem. If so I will also get the original checked/repaired at ECU testing. Good point about the Steering angle sensor - I’ll make sure to calibrate it, alongside finding the sweet spot for the spacer ring.
