EPS light, SPORT Button Stays ON
demos
New member
Hi fellas, my 2003 3.0 Z4 got the steering light on, no power steering, can't diagnose or communicate with the EPS ecu. I've read here that if the sport button also doesn't work then 100% it's an ECU problem. In my case the SPORT button stays on meaning the LED on the button is lighting, but pressing it doesn't turn it off it just stays ON.
A- So is this what is meant by "SPORT button doesn't work" which means it's an ECU problem? Or could it be something else?
When I delete ALL errors from entire car, all ecus, even though the EPS is dead, and turn ignition ON/OFF the EPS used to work and come back alive, and the power button works (I can turn it off/on by pressing it) and reading the ECU gives no errors.
Then after a few days, it would die and come back alive if I delete errors on GM5 (I'm getting Central Locking Relay errors on GM5).
Then few days when I let the heater on and idle car for a while EPS would come alive but light still on cluster so I cycle KL15 on/off and error would go away.
B- Would updating firmware on EPS solve this issue (tempt the car in any way to catch the moment where eps_e85 would come alive and update the software)?
Current AIF/ZUSB is 6763413 & never changed since 19.02.2003.
I'm trying to avoid breaking my back (bending over backwards to remove the motor), then breaking my wallet (shelling out 300 quid or so, with a possibility of getting unit back and being told oh it's no good get another one, or having it work for a day or so and re-sending only to be told it's no good, or I'm no good, or the torque sensor is no good...etc. as I've read on some threads here).
Thank you.
Usually the light won’t come on, but if you cannot communicate with the eps ecu I’d still suggest that is your issue.
Where are you?
I’ve changed many of these now and can either send off a u/s one and get it repaired to fit to yours, or I have a good used one I could swap in for you.
Repaired is £295
Used is £100
To replace either would be £75 labour.
I don't understand the options though, are you saying you could sell me a used motor for £100? If so, how far are you from Oxford OX4? Thanks!!!
Ecu Testing will repair a motor and give it a lifetime warranty for £295.
If you cannot afford that I would sell you a working secondhand one for £100.
If you couldn’t swap it yourself I could do that for an additional £75, regardless of whether you fit repaired or secondhand.
However, I am near Norwich.
If you wanted me to come to you I would obviously ask you to cover my fuel costs.
How old is the battery. Think I would look at that as a first step. If it's not that old try disconnecting battery for 15 minutes then try again.
Thanks alot, yes I'd rather much get a used one. I tried to message you but the system/forum wouldn't allow, can you post it to my address?
I’m not back from Grenada until 13th. Once you have 5 posts you can DM.
As long as you’re sure it’s not due to an old battery
