Well I thought it was sorted, Its happened a couple of times since the original and been re set both times only to re appear.
Sometimes when it is started there is a bellow of smoke out of the exhaust; I wonder if this could be a symptom of sticky piston rings with it standing around and not being used much, therefore showing a weak mixture on bank one on the readings when its checked.
Any suggestions?
