engine noise!
zee1
 Torquay Devon
Hi all my next question!! My 03 2.5 with only 24k miles fsh sounds lovely really quiet and as it should, when it is ticking over it occasionally makes a single tap noise which I can feel when I put my hand on the engine, It is not a knock and not a tick somewhere in between other than this it sounds glorious and drives perfectly I haven't driven it for a while since I bought it as it's not taxed and has been tucked up in the garage I don't think its much just looking to see if anyone else has this
Thanks again Steve
It could be old fuel, I’d fill up with a fresh tank of good stuff and see how it runs then :driving: If you happen to have a code reader it would be worth plugging it in to check for a slight misfire.
Thanks for your reply it doesn't sound like a misfire it is just a noise :!: as I say like a single tap. I know it is difficult to diagnose problems over the net are there any members in Torquay?
Is this with the air-con switched on or set to auto? if so it could be the compressor kicking in and out, worth checking.
With low miles and little use I would guess a sticking valve adjuster, I would take it for a good run, drain the oil, change filter and fill with fresh oil and take it for an Italian tune up.
