Engine management issues continued!!
sniper
New member
Hi
Thanks for your advice Alan J, I have mentioned it to the dealership.
I am being told a fault code was showing a miss-fire on three cylinders they have changed the coil packs around (again!) and same with the spark plugs. The issue is this is an intermittent cold start problem, and when they test it the fault is not repeated at present anyway! Again anyone out there had similar issues or any suggestions????
Ive owned my Zed for about a month now prior to this I had a 325 ci convertible, its an 03 plate in silver again another convertible (I'm hooked on them!!) it has a nice set of AC alloys which Ive had dipped and sprayed, Im not sure what comes as standard but I have heated seats and sat nav with a six disc changer and when it works I love the car!
You say they have changed the coil packs around? Or have they replaced them as there have some issues with OEM coil pcks. Just changing them round shifts the problem from one cylinder to another.
