Engine light on - P1168 code
ghawk
I had my engine light come on after a long run and fitted a code reader which showed error code ~P1168, FRP sensor low. This means low pressure fuel rail for bank 2. Anyone had this fault before? Any ideas what might be wrong?
many thanks - sounds complex. I may reset the code and see if it comes back before I spend too much time on it
No worries at all. Reading that thread, it does seem quite involving! Good luck with the reset, otherwise maybe get her plugged into an indy diagnosis machine or go see your local stealer.
