Hi All
I've had the yellow engine light displayed for a little while now. Just had Inspection 2 completed by Specialist Cars and they said the fault code is 2A2F which apparently indicates there is an issue with the DME mixture control and that the mixture is too lean.
Their first investigation step would be a smoke/emissions test.
The engine is apparently running fine otherwise. 60,000 miles.
Questions:
Does any one have experience of this code and what caused it?
For this type of issue does the stealer have any diagnostic capability advantages or would I be as well to go to a local independent or some sort of specialist?
Questions:
