elliesmith
New member
I bought a 2005 3.0i about a year ago and have found multiple problems with it, some of which I have fixed. The problem that seems to not go away is that I start it up, it will run for a little bit, then die. Turn the ignition off, back on again, starts right up, runs for a little, stalls but then keeps running, but then dies again. I may have to do this 3 or more times before I can feel comfortable that it will not die while I am driving it. Which has happened before. Then it is fine for the duration of the drive. Someone suggested it was the master or motherboard? If so, is that costly to fix?
