So, would something like this fit on the standard engine, and if so, would it make much of a difference
http://pages.ebay.com/link/?nav=item.view&alt=web&id=291152908884
Genuine ALPINA
Used
Tested
Mint Condition
ALPINA Big Bore Inlet Manifold Kit *Complete*
Will Fit M50 M52 M54
Ultra Rare
Gives Massive Power Increase To Engine
You Get All Parts To Fit.Included In Kit Is:
ALPINA Aluminium Inlet Manifold 11 61 130
ALPINA Manifold Gaskit /Head 11 61 132
ALPINA Throttle Body,manual not by wire 13 54 639
ALPINA Airmass Meter 13 56 700
ALPINA Air Sock 13 70 164
ALPINA 3.3 Cover 13 54 156
ALPINA Engine Wiring Loom 61 11 138
ALPINA Engine Ecu And EWS Kit MS42 13 56 696
ALPINA Air Box Top 13 70 165
ALPINA Air Box Bottom 13 70 166
ALPINA Fuel Pipe X2 16 10 182
ALPINA Throttle Cable 35 41 107
BMW Fuel Rail 13 53 1 436 468
BMW Injectors S52 EVO USA X6 13 64 1 703 819
BMW Fuel Preasure Regulator 13 53 1 436 110
All Brackets And Pipes To Retro Fit To Your Car
ALPINA ECU And EWS KIT
Throttle Cable And Peddle *Manual*
This Is A Comprehensive Kit Removed By Our BMW Trained Technicians
Says it will fit on the m54 engine and that it improves performance dramatically...
Thoughts? I'm hovering over this!!
