Engine Bay Detail
Beeacon
 Manchester, UK
Full external and internal clean, seal restoration, and got around to fully cleaning the engine bay today!
Just need to figure out how to clean the exhausts without affecting the brushed chrome finish.
Engine Bay Clean Method:
https://youtu.be/6LwCbmvLYb0
Work on a cloudy day and cover any electrical or sensitive components with plastic sheeting or a carrier bag (alternator / ECU housing / exposed air filters). Make sure all caps and dipsticks are fully secured. Also wear gloves, degreaser is nasty stuff on your hands.
1. Spray a degreaser (Autoglym Engine & Machine Cleaner) on the underside of the bonnet and let it dwell for a couple of minutes. Use large soft wheel brushes to clean the underside of the bonnet. Do not touch the heat shield.
2. Rinse using a normal hose or a pressure washer on the lowest setting.
3. Rinse the engine bay to remove loose dirt and contaminants.
4. Spray a degreaser (Autoglym Engine & Machine Cleaner) in the engine bay and let it dwell for a couple of minutes.
5. Clean the engine bay with wheel brush, bendy thistle brush, and small detailing brush for hard to reach areas.
6. Rinse.
7. This can be done two ways: 1) Apply a wet dressing (Autoglym Vinyl & Rubber Care) and leave to dry before buffing off. 2) Dry the engine bay using either microfiber drying towels or air dryers/leaf blowers. Make sure it’s completely dry, then using a spray dressing to restore faded plastics.
8. Remove protective plastic bags and start the engine up and leave to run for a few minutes to dry out those last few hidden recesses. Done!
Yes, Autosol does a great job! :thumbsup:
I just need to get a bit more dextrous. :(
Doddsy said:
Those tips should just pull off if standard
They would, but I'm quite glad it isn't standard! A previous owner had a cat-back system made for it - which sounds much better. :lol:
Well, I got some Autosol, a wool polishing drill bit, a microfibre cloth, some latex gloves and went at it! Here are the results on the exhaust, they look a bit better but I was fearful of rubbing the rest of the paint off.
Beeacon.
After:
Before:
You’ve only cleaned half of them though :poke:
