Hi
On Friday, there was a yellow thing, believed to be called 'The Sun' in the sky. Excellent, I thought, time to lower the roof on the Z4. All was well. I stopped and put the roof up to do some shopping and then back down for the drive home. When I got home I pressed the closure button and the roof came up about 1/4 then stopped and slowly sank down again. Looked for the release cable in the boot and that has stuck solid.
My question is, can you gently pull the roof shut with no release pulled? I'm going to check fuses tonight in case I'm lucky and I can get it to shut. Lucky I had a cover but it's very old and water still got into the car as it's done nothing but rain since! Any help would be greatly appreciated. I'm praying to the good lord above that my motor hasn't failed but am thinking the worst. Needless to say, whatever happens, the drain holes are going to be checked and cleared. Car is a late 2006 3.0Si with M-Sport.
I put the roof down and up a couple of times without releasing the cable, after it had failed. It's very stiff and takes some effort, but if you do it gently and slowly and from both sides at the same time then you won't twist any of the roof structure or mechanism, which was my main worry.
