If you really think that the Battery cable is your problem, then you MUST replace it. It is tied directly into the SRS monitoring system so that (the SRS) can monitor the cable for faults.
B+ Monitored Battery Cable
1. Outer insulation
2. Monitoring Shield
3. Insulation of aluminum cable
4. Aluminum cable 35mm2
The E85 B+ Battery Cable is routed from trunk area along the underside of the car into the engine compartment. If the cable is damaged in an accident or while driver over an obstacle,
the BST is activated, protecting the vehicle from further electrical problems.
The battery cable monitoring occurs via the low impedance shield of the battery cable, the monitoring shield. The monitoring point in the trunk at the BST is connected to the SBSR
and the other monitoring connection in the engine compartment is connected to the SBSL. B-Pillar Satellites (SBSL and SBSR)
Battery Cable Monitoring
The battery cable is diagnosed by a special circuit between the SBSL and SBSR satellites.
The battery cable diagnosis takes place across the low impedance shield of the battery cable (monitoring shield). The monitoring shield monitors the state of the battery cable
as follows:
There are connections to the left B-pillar satellite and the right B-pillar satellite at both ends of the shield. This means that there is usually the same voltage at the
analog/digital converters in the satellites. If the voltages differ, there is a fault.
The monitoring shield consists of a low-impedance metal mesh. A connection cable exits from each end of the monitoring shield (at the safety battery terminal in the luggage compartment
and at the battery earth point in the engine compartment).
The connection at the safety battery terminal in the luggage compartment is connected to the right B-pillar satellite. The second connection cable in the engine compartment is connected
to the left B-pillar satellite.
The satellites contain analog/digital converters that are connected to the microprocessor of the satellite. The connection cables of the battery cable diagnosis are connected to the A/D
converters.
The right B-pillar satellite contains a pull-up resistor.
The left B-pillar satellite contains a pull-down resistor of the same size.
The voltage supply of the satellite (approx. 10 V) is applied at the pull-up resistor. Ground is applied at the pull-down resistor.
The very low-impedance cable and the resistors of the same size mean that around half the voltage (approx. 5 V) is applied at the A/D converters.
Every 250 μs, the values are measured, triggered by the synchronization pulse. If the battery cable is OK, the values are transferred every 20 ms to the SIM. If a significant deviation
of the values occurs, the new values are transferred immediately.
In the following cases, the battery cable is cut off by the safety battery terminal from the battery and the alternator is switched off:
• Short circuit to ground (body)
• Short to battery positive
If the outer insulation is damaged (e.g. due to friction/scuffing), but the monitoring shield has no connection to ground, the following case could occur:
Moisture (rain) would mean that the voltage would gradually fall. A short circuit to ground would be detected, but the safety battery terminal would not be triggered.
The entry "Implausible measured value" is set in the fault code memory. This would be indicated to the driver by the airbag warning lamp.
Service Notes
The following must be observed by Service:
• Battery cable diagnosis
• Safety battery terminal
• Airbag warning lamp
If the shielding of the battery cable is damaged, the battery cable must be replaced completely.
It is not permitted to repair the shielding.
If the safety battery terminal is activated, the battery cable must be replaced completely.
Repair is not intended.
