Drivers side is no longer going all the way up with one click and without having to hold it on - am i doing something wrong? Are the switches two stage, perhaps partly worn out?
Yep, it sure did, chaps, I followed the simpler instructions further down that link and that worked a treat. One touch window open or close ahoy! Thanks guys
When following the procedure do you press the button fully the whole way or just to the first notch? I've tried the procedure and at one stage my window wouldn't open at all; I had to turn the ignition on & off.
