Electric coolbox in the boot
Farao
For my trip to Italy I was planning to buy one of those electric coolboxes that powers via the 12v cigaret outlet. Has anyone tried to create such a power source in the boot/trunk? Thanks.
i looked to do the exact same thing for my trip to france - only problem was the cool box took up most of the boot space so i decided against it.
it should be pretty easy to hook up as the battery is in the boot, i planned to just clip it into the battery & either cut a hole in the carpet or run the wires up to the side - just make sure you fuse it & switch it off if your away from the car for a while as it could run the battery down.
I often carry a small cool box with me when I travel and have added a 12 volt plug in the trunk/boot for that purpose. It is attached to the battery and has a 15 amp in line fuse.
Thanks guys.
@WLH: That is exactly what I was looking for...do they sell the '12 volt plug to battery' as standard? Or did you had to do some modification on the battery end of the plug? Thanks.
(sorry for the stupid question, but I'm a real a newby when it comes to these things :oops: )
