I am considering to install Eibach Pro-Kit springs on my newly purchased Z4.
It is unfortunately without M-suspension. And what I want to achieve is a lower car, and like a bit stiffer.
For this purpose, I found Eibach kit perfectly.
But! I have read a lot about camber angle, but not found a clear answer. Should this be adjusted by fitting Eibach? A little bit of negative camber would probably look ok, but I will not lose grip and I will not wear the tires unevenly. (or how to explain it in English?
If camber has to be set, then how to do that?
Is it easy or do I have to buy adjustment set?
Hope someone has specific experience with the kit!
Let me hear what YOU have done.
Thanks in advance!
Thanks in advance!
