Eibach springs ground clearance
Zikim
I am considering fitting Eibach springs all round but concerned with ground clearance. I have a 3.0i SE prefacelift with front aerodynamic bumper and worried that I will start scraping across speed humps, etc. I have M Sport suspension as standard which is already lowered by 15mm but will the Eibachs at 15mm lower again cause a problem, my zed is a daily drive. Has anyone had any such problems since fitting Eibachs?
Also, is the the to Eibachs worth it from standard sport springs?
Mine's on Eibachs and I much prefer it, you do have to be a little more careful on speed bumps etc but it's generally fine. The car looks so much better lowered.
It will be fine on eibachs. I had fk springs on before them and it was no good in terms of being a daily driver, so changed to eibachs and now it's fine. You still need to go slower over speedhumps, but there is enough clearance to negotiate them easily.
Mine is a 3.0si SE with non-sport suspension.
Intention is to go for B12 Pro Bilstein/Eibach kit, I guess it won't make any problem as well?
Thanks.
