Eibach Coils & camber kit question.
Bushido
Short & sweet - do I need to get a camber kit for the rear suspension on a Z4M R (06) if I install Eibach coils?
The lowering is supposed to be half an inch only - in the rear that is.
Having this done in the next two weeks so replies from those with experience with the Eibachs wil be greatly appreciated.
(Rather get the lot done together if it needs be.)
Simple answer, if you just want to lower the car then no, coil springs alone are ok and there is a bit of adjustment with the standard suspension components.
If you want to adjust your camber and toe to any great extent coilovers may be a better option than lowering springs.
Do not want the rear tires to wear away - expensive exercise.
Anyone know more about this:-
http://cgi.ebay.com/ebaymotors/BMW-E85-Z4-3-2-M-SPORT-SUSPENSION-II-CONTROL-ARM-ARMS-_W0QQcmdZViewItemQQhashZitem20b07166c9QQitemZ140399175369QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Was there really a change in specs for the M's control arms & bushings? If so - why? Is there a marked improvement?
In the dark here...
