EBC yellow stuff pads
Z43.0Si
 Surrey/Hampshire
Anyone got any experience of these on their Z? I've been recommended these for use on a pending track day.
Subbed as funnily enough, I've got the same question.
If I could cheekily ask too, what discs do people rate?
Had them on my Fiat, was rubbish on track.
Maybe 340bhp, 1400kg, fwd was too much for them tho. Was ok on road.
Carbotech or PerformanceFriction were the pads to use, altho I don't know if you can get them for Z4.
Never had a problem with Yellowstuff on a 1800kg, 340bhp, RWD e34 M5, or the Z4M. But I took some driving instruction in how to brake properly, without being the last of the late brakers :poke:
Did swap to Bluestuff on the recommendation of a fellow marshall, who used to provide a 50% discount on EBC products, so a full set was about £90 :thumbsup:
He's retired now, but I still use Bluestuff or Pagid RS pads - depending on what I can get my hands on at the time and how much cash I've got. The Pagids wear out much quicker, are more expensive, but perform better. The EBCs last much longer, are much cheaper, but are not quite as good as the Pagids.
I used Yellowstuff for a few years and found them to perform well on the road and track. However, I had a problem with one set where the friction material delaminated from the back plate. They had only seen road use so hadn't been exposed to significant heat cycling. EBC blamed a manufacturing fault.
On average, they would last only a couple of track days at best and often showed signs of overheating when I changed them. Unlike mmm-five, I am the very last of the late brakers and I prefer short, technical tracks without long straights so brake cooling is more of an issue for me!
I've since switched to Bluestuff and fitted supplementary brake cooling ducts as well as solid bushings to the calliper bolts. This has improved the consistency of the feel of the pedal and so increased my confidence in the brakes. In combination with KW Clubsports (which eliminate the significant pitch under hard braking) this by has markedly shortened my braking distances.
One important step to reduce brake temperatures is to switch off the DSC so the car isn't braking individual wheels every time you corner hard.
As Mmm 5 , I've had them in a few cars and they've always been ok on the ring , including a z3 m coupe . Change the fluid for a higher temp at the same time . Instruction is the best way of making a car faster though .
Yes, I forgot to mention uprated fluid and SS braided brake lines. I used ATE Super Blue for years and found it performed better than more expensive fluids such as Motul RBF600. They're no longer allowed to sell blue fluid but I think ATE TYP200 is the same specification.
The blue was the best by far , especially as you can see when it's flushed through , type 200 is the same spec , just a pain when working by yourself as you can't see it in the pipe .
I was aiming for the ebc red stuff.
Do you guys rate the blue for road use??
I mean rate from your perspective, not what's said on their website
They're fine for road use. I haven't found them to be ineffective when below a certain working temperature (as some track-oriented pads can be).
Yes I had the delamination aswell on my yellows. Been using PerformanceFriction or Carbotech XP8 pads for years - just in a different leage.
Of course on a less brake-demanding place like Nordschleife the EBC Yellows could be ok.
I would have stopped using EBC pads when it happened to me, but EBC offered me free discs and pads. It was then that I tried the Bluestuff and found them to perform really well on the track without losing road performance. I've not had problems with EBC pads since and I must have used half a dozen sets of Bluestuff by now.
I've said before , reds lasted half a lap of the ring before fading into oblivion , came back to me after cooling off and weren't to bad but I wasn't going to try that hard again . This was in a 3ltr e85 with new m tec grooved discs and ive been going over there for a dozen or so years , I'm definitely not an aggressive braker and would never fully commit around that track .
I've never tried blues but yellows have always been fine in a few different cars , although blues are starting to look worth a try .
Ferodo 2500 for me, if they're available. Try Demon Tweeks. Feel no different than road pads from cold and I've yet to feel any fade. Not bad on dust either. Used them on countless track days in my Cosworth, which is a similar weight 1150kg but far more power and my Escort which is about 900kg and over 250 bhp. Both run AP calipers. The set in the Cosworth has done at least 5 and still have life left! Prices are reasonable too!
After lots of research, I've just ordered front and rear Tarox Strada pads, hopefully I'll be happy with the result.
