e89 wheels on e86?
corsaire77
 Warsaw
With the snow still on the streets of Warsaw, I'm toying with different original wheel ideas. I've been through all the MVs, and now something else has come to my mind.
Would E89 18" wheels fit on the E86?
The sizes are
front 8x18 ET 29
rear 8,5x18 40
and the tyre setup matches the E86.
The offset calculator indicates they would extend about 20mm and 10mm respectively.
Someone here has fitted the bigger 19", apparently with no problem.
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=36232&start=30
Rears will be ok, not sure about the front ones.
Although my track wheels are 8x17 et34 so probably et 29 will be ok.
TapaTalking
