E89 spacers
Johnbmwz4
 North Yorkshire
Anyone here fitted spacers? If so what sizes on front and rear and any recommendations on where to get them from. Had them on my E85. I think they were 20mm on rear and 15mm on front . Purely for aesthetics obviously.. They made the stance on the E85 look much better.and thinking the E89 could do with them too.
I think the sizes you would want would depend on what wheels your E89 has, so it might be worth adding that.
Any that fitted your E85 ought to fit your E89 as I'm pretty sure the bolts are the same size.
With 326Ms you can add say 5mm on the front and 10mm on the rear on stock tyres..
On the front you really don’t want to mess with the steering offset..
Which would you suggest? Hubcentric?
Looking at a few posts on here and some have only fitted spacers on the rear . I’d be happy with that. So 15mm is the highest I can fit with 326 wheels?
The only spacers you should use are hub centric..
With 326ms 5mm on the front is a flush spacer as there is not enough metal for a spigot..the rear 10mm has a spigot..
