Looking to retrofit. Looking for-
1) bulkhead liner inside the boot part no 7341670
2) access door in the boot - 9181609 is the "sack" according to realoem
3) the shelved box, can't find a number for that
Have you tried ordering them from Bmw? Otherwise its a breakers yard. If you don't have the access door inside the car, you will need to be ultra careful when cutting the carpet on the bulkhead.
Just wondered if anyone has retrofitted the ski hatch / storage compartment. If so was it an easy job or did you need to remove lots of the interior / boot trim to fit the new bulkhead ( part number 51477341670 ) and fit the replacement carpet ?
Can anyone confirm that if the Hi-FI Speaker System ( DSP S676A ) isn't fitted than you require interior carpet with part number 51469171841
