E89 radio removal
There is a panel below the radio that you need to remove. It's held in place by 4 studs that just prise out, use a plastic panel extraction tool for this as you don't want to damage the surrounding panel.
Behind this you'll find 2 screws below the radio fascia, remove these and your radio can now be, gentle, pulled forwards.
If you hear a "clicking" type noise as you pull it forward then you are pulling the serrated optic cable against a strip that hangs down behind the radio, just put your hand in and free it off.
Hopefully that should sort you out.
try this
https://www.newtis.info/tisv2/a/en/e89-z4-sdrive35i-roa/repair-manuals/65-audio-navigation-information-systems/65-11-radio-cd-dvd-changer/8IGHCjt4
All the info you need
Gaffa22 said:
try this
Oooo that's good, I like that site not seen it before.
Not sure what car the OP has but there is 2 versions of radio/cd. Yours must be the same us ours with no idrive/nav as ours has the panel under the radio/cd as well.
I think models with idrive/nav doesn't have the panel under the radio/cd and instead has trim that goes around the radio/cd.
Good point...
Here is the iDrive version.....
https://www.newtis.info/tisv2/a/en/e89-z4-sdrive35i-roa/repair-manuals/65-audio-navigation-information-systems/65-12-radio-audio-amplifier-headunit/8K54Nd9V
