LordLolzeye
Hello,
Has anyone experienced the following symptoms:
I just changed the spark plugs and after this happened:
When starting the car a weird squeak comes from behind (I think) the engine (N52B30). Also, when idling the car, the squeak is less pronounced (every now and then, it's not a permanent squeak). It probably has nothing to do with the spark plugs, since the engine runs completly fine.
I taught it to be a bad starter motor that does not retract, but i'm probably wrong, since that should produce a permanent noise.
Any ideeas?
Any ideeas?
