e89 35i - Fast Road Setup/Suspension Shopping List
MarshMA10
Hi chaps
Time has come to spend some cash on improving the e89 handling following a tasty summer bonus :evil: and a decision to keep her a bit more long-term rather than moving on to something else!
Background: my car is a 2010 e89 35i on stock suspension and springs, which have no record of being changed. It has a shocking mismatch set of tyres which is my personal pet peeve. It has been tuned a bit and is around 380hp. It gets regular spirited twisty road driving, and I would like it to be track-capable, although it'll only be a few times a year max.
Tyres:
Front - 2x Goodyear Eagle F1 225/35/19 on 19x8.5J rims
Rear - 1x Falken and 1x Nereus Sailfish :( :( 255/30/19 on 19x9.5J rims
I plan to replace the 2x rears with new Michelin PS4s 265/30/19s. My personal favourite tyre. Moving from 255 to 265 because the current tyres have a slightly 'stretched' aesthetic which I don't particularly like. Pics attached. As you'll see the PO has also absolutely ragged the rims against some kerbs so they're in deep need of a full refurb. I plan to replace the fronts with 225/35/19 Michelins, and keep the Goodyears in the shed as emergency spares... The rears can be ceremonially burned.
If anyone thinks I should use a different tyre size I'd be keen to hear. Changing 255 for 265 appears to result in 91.1mph at indicated 90mph, 1% increase in diameter, so fairly minor. Moving to 275/30/19 (max recommendation on a 9.5J alloy) takes that to 91.8mph @ indicated 90, 2% increase in diameter.
I anticipate spending perhaps ~£1000 on tyres, refurb of rims, and geometry realignment.
Suspension:
I'm much more at a loss here, regarding what to upgrade on an e89. Shocks, springs, ARBs, polybushes, control arms, etc.
The qualities of handling that I like a lot about this car are chiefly:
- ride height - appears to balance looking good with excellent ground clearance (never scrapes straddling a speedbump etc.)
- all round compliance/comfort - it never feels crashy or jarring.
- braking performance - really strong, no need for any improvement here for me.
- acceleration performance - again, plenty for this chassis I think.
The qualities I really do not like are:
- alarming weightlessness on rear tyres when changing up a gear after full throttle (weight transfer forwards) - this alone would prevent me taking this car on track, to be honest.
- excessive body roll when cornering - feels like you could get close to cocking a wheel in this car, if you tried. Again, I think this would prevent me taking this car on track.
- soggy turn-in/understeer tendency - it's not terrible compared to expectation from online reviews before I bought the car, but it's definitely not good. Are there recommended fast-road geometry settings that might improve this - or spacers on the front wheels, etc? Appreciate maybe the 35i engine is just a bit too nose-heavy for the chassis perhaps.
- single tyre fire - evident that this car does not have an LSD. I am not sure I'm willing to get into it to this level, but if it is not too painful I'd like to have an LSD. Was there any factory option, or something?
- excessive dive under full braking and squat under full acceleration - relation to point 1 aside, these are relatively minor complaints by comparison, but definitely not 'sports car' quality.
I'm really here looking for suggestions on where to spend the money to improve these attributes. I don't want to turn it into a polybushed track-car diva, but it really wants some better weight control. Is it worth looking at fitting adjustable dampers that firm up considerably for sport mode, etc?
Love to hear all your suggestions about what's improved the e89 ride for you.
Thanks all.
C
So simple solution…
Conti SC7s..much better on E89 than MP4S…235/35 19 and 275/30 19
Bilstein B8 shocks with Supplex MSport springs at correct weight
Meyle HD steering tie roads
E90 M3 steering linkages upper / lower
H&R ARBs with rear on middle setting
New RTABs and rear links from Hardrace
Quaife LSD
Ideally adjustable camber arms/toe plates and camber plates
Simples…
Reamesy said:
B21 said:
So simple solution…
Are those tyre sizes on 8.5 and 9.5J standard rims or the 437M rims?
Currently I have them on both my Apex Arc 8s on 8.5j 9.5j and on my 437M on 9j and 10j..
May go slightly larger on the 437m next time..maybe width maybe profile..there’s no 285/30 in SC7s..
I’ve now moved away from any form of lowered suspension…MSport is about as low as I will use..plus now tempted to go higher profile..
For fast road use riding out bad road surfaces is my priority…to many bent wheels..
B21 said:
Reamesy said:
B21 said:
So simple solution…
My car had M Sport suspension delete from factory. It’s perfect in handling and comfort for me. 👍
I know from the VIN decoder my car had the following spec:
- Vehicle Options: AS70A KRADA L812A OKOSA P337A S1CAA S1CBA
- M Sports package
- 19" M light alloy wheels double-spoke style 326 M with tires of different makes and types
- Light-alloy wheels star spoke 58
But not sure what this means for shocks and springs. Is it likely to be the “M Sport Suspension” that’s currently fitted to it?
Still trying to find a good supplier for the bilsteins.
Yes bog stock MSport dampers and springs..if the springs are in good condition just B8 dampers..
