Buckz said:86 will be a better drivers car, TT will be a better car as a daily I'd sayBoth have pros and cons but I'd need to live with a TTS before I'd be able to tell what is better, I like RWD and fat engine up front.
JimBob78 said:When you say boring, is that because it won't oversteer or something else? I wouldn't hang the back out on public roads anyway and never seen anyone else do it so I'm not convinced that that's a factor for me personally but I probably need to drive one and see
Angelus666 said:The magnetic dampers are ok, but it rides better with them turned off. We had 310hp on our TTS and it shifts along nicely, but you need the turbo to spool up and it comes in one big hit around 2.5rpm to 3.5rpm and then it's gone. The noise is average, it's a 4 cylinder and inside you hardly hear much going on.
Girls prefer the TT if that helps at all.... :?
JimBob78 said:I think I just need to try one and see for myself...
The other option was to go back to Renaultsport and try an RS250 or 265 which are apparently pretty good...
