Fred Smith said:Special Kay said:I think it all depends upon how you intend to use the car. If you do intend to track the car at some stage, I would definitely fit a more purposeful suspension set up. If your just using it on the roads, then I'd probably just opt to do a refresh with some B4s, and maybe a set of Eibachs for a slightly lower look, or suplex springs if I wanted the OE setup. It's decision time, but I think you can make the correct choice with alot of confidence. Good luck![]()
Thank you - road mainly, so I should go sensible.
Further to my question just above. Would there be an issue with installing Suplex 06231s, and then leaving the car for a while before putting 06248s on the front? And same question but with Eibachs? Or would it be utterly insane to change the ride height at the rear and waiting to do the front?
Fred Smith said:Sachs are the standard, go-to option, but rears no longer seem to be available.
