E86 Front control arm - Replacement bushing choices
Phippy
Hi all,
Recently bought a set of PowerFlex bushings but turns out they are too small (quite annoying as they definitely said the were for E86!)
What i bought: PFF5-5601-60 Powerflex Front Wishbone Rear Bush, Aluminium Outer fit BMW (60mm)
I now know i need a 66mm diameter!
PowerFlex only seem to offer them in offset (not the end of the world if i have to go offset as it will improve handling), but would rather have non-offset.
Does anyone have any other brands i could consider? Or a link to an ebay item?
Many thanks!
Solved - for anyone else looking you need either;
PFF5-5601 POWERFLEX FRONT WISHBONE REAR BUSH, ALUMINIUM OUTER FIT BMW
or;
PFF5-5601G POWERFLEX FRONT WISHBONE REAR BUSH, CASTER OFFSET
Bushin size = 66mm
