E86 final drive
Liam22
Herts/Cambs
I've seen conflicting information about the E86 3.0si final drive ratio (diff ratio). Manual transmission.
Where is the definitive data? I'll soon have the diff off the car, so I guess that will tell me, so long as the label is intact.
IIRC the E86 manual is 3.46 with the E85 3.0Si manual equivalent being 3.23. They both have exactly the same gearbox so its this different ratio diff that makes the E86 feel livelier. The prefacelift 3.0i manual also uses the same gearbox as the 3.0Si cars but with a 3.07 diff. Again this is part of the reason the 3.0Si cars feel a bit livelier than the pre 3.0i cars
Realoem list the ratios for each diff
