Forum collective hive mind- a view please
I have an E86 with electrical issues. Long story short I think it has had a combination of water ingress and fuse overload leading to pretty significant loom damage.
Also, add in the mix lots of previous attempts to fix.
Now, the simplest fix in my mind is replace the loom, a tedious job but doable.
I've found a loom, but the spec of the car is not like for like- donor car doesn't have xenons this one does. That's not going to work is it?
So I need to either:
1) Find a loom with the majority of similar components and functions
or
2) Repair the damaged sections, either using new wiring or donor sections from the donor loom
or
3) use the donor loom and rewire the missing loom components (like xenons)
Am I right in these assumptions?
What would you guys do?
Stuart
or
or
Stuart
