E85
Mines the same. There is a metal clip inside the door, which holds the barrel in place. It's either came loose or broken. I haven't got around to fixing mine yet. I believe you need some sort of special tool to remove the door handle.
If i remember rightly, you can't see the back of it if you remove the doorcard. I think it's covered with metal.
This may help
https://www.pelicanparts.com/techarticles/BMW_Z4M/56-BODY-Door_Handle_Replacement/56-BODY-Door_Handle_Replacement.htm
