markeg said:When one of my xenon bulbs went, I upgraded mine to Osram Night breaker DS2 bulbs, seem a lot brighter. I also adjusted the beam up a couple of rotations and cleaned the lenses to remove the pitting. I find mine are great now...
When you say they are not as good as they should be,is it brightness, beam pattern, throw, or all?
EdButler said:My Z4's Xenons are fantastic... Your auto adjusters may be broken if they are focused very low and wont raise up. This can happen when changing suspension components.
You can disable them using INPA/BMWScanner, and manually adjust them higher. Just dont tell your MOT'er...![]()
Also give your lights a good polish.
Zikim said:EdButler said:My Z4's Xenons are fantastic... Your auto adjusters may be broken if they are focused very low and wont raise up. This can happen when changing suspension components.
Mine is a 04 3.01 SE and does not have the auto-adjusters, it has a manual 0-1-2 rotary dial which I have set to 0 which puts them as high as they can go.
scotty597 said:If you have an adjuster rotary dial on the dash, you dont have xenons. I believe xenons are auto self leveling only due to dazzle. Halogens have the manual adjuster. The other way to confirm it is under the bonnet. Should be a ballast each side and High Voltage stickers if they are still there.
JayEmm said:Word of advice, some of the super-duper-ultra-ultimate bulbs do not seem to last very long. My Peugeot used to go through a bulb every 5 months or so - probably wise to keep a spare or spare pair handy.
omar said:Aftermarket xenon kit, a good polish of the headlights and maybe one turn of the white adjuster screw and it will be so much better. Best £100 you'll ever spend on the car.
Mot is fine... Been to 4 different testers and never even had a question. Advantage of projector lamps is that they do indeed look like xenons hence ops confusion.
I wouldn't waste money on marginally brighter bulbs... Projector lamps with halogens is just inherently rubbish. Even the F10 is criminally bad without xenons.
