E85 M sport suspension springs
jamie_z4
Veteran
Full set with no cracks just a bit of usual surface corrosion on rears
Removed from my 3.0i which came from factory with sport suspension
Ideal upgrade for a 2.2 or 2.5i with standard se suspension
£40 Posted or £30 collected from Preston
Jamie
Jamie
Would you split fronts please?
I have a 2003, 2.5 with sport suspension, but it is a bit lower on one side, so thinking of changing springs as I presume the springs are responsible for ride height. Cost to post fronts only please
George
I"ve still got mine up for grabs, rears have done 6k the fronts ?
I only need the rears - how much you looking for and where are you located?
I"m in Worthing ca 10 miles west of Brighton, £25 ok ??
Simon,
I have a set of M Sport rears, I can have them delivered to you for £20. Picture below shows the rears at the front, with the front springs behind them.
George7 said:
Jamie
George
I have a set of fronts if you're interested, they have some surface rust as seen in the picture below. I have sent you a PM
