Sent you a PM!synthedup said:Hi, I have a complete black unit in the garage doing nothing. Make me an offer and its yours. It's no use to me. Cheers.
As far as my unit is right now, the black switch part just comes off easily, probably because it's broken. I think I can strip the new one down and replace the damaged parts alone. If not then I'll just go ahead and try to program it into the car.ph001 said:The entire unit is known as the LCM (light control module) and contains things like vehicle mileage. You can’t just swap it for another one unless you get it coded to the car (otherwise it brings on a ‘mileage tamper’ warning on the dash).
You may be able to strip it down and just remove the switch part if yours is just mechanically damaged.
