C craiginuk Member Sevenoaks, Kent May 19, 2023 #1 Am I correct in assuming that the coupe and convertible boot trims and carpets will be different? Looking at a Coupe that has had the boot carpet stripped out for track and am guessing it will be hard to find a replacement...
mmm-five Lifer Liverpool May 19, 2023 #2 The part numbers are different, so I'd assume the mats are different too. e85 (including M) = 51477016687 e86 (including M) = 51473420916
C craiginuk Member Sevenoaks, Kent May 19, 2023 #3 Thanks is there a parts fiche you're finding those on mmm-five?
mmm-five Lifer Liverpool May 19, 2023 #4 craiginuk said: Thanks is there a parts fiche you're finding those on mmm-five? Click to expand... https://www.realoem.com/bmw/enUS/select e85 Trunk Trim: https://www.realoem.com/bmw/enUS/showparts?id=BU51-EUR-10_2004_E85_BMW_Z4_30si&diagId=51_4953#51477016687 e86 Trunk Trim: https://www.realoem.com/bmw/enUS/showparts?id=DU51-EUR-10_2005_E86_BMW_Z4_30si&diagId=51_6152#51473420916
