SOLD E85/E86 ISOFIX Passenger Seat Bracket I have 2 of them BOTH SOLD
Sold
Cv6benplus
 Coventry
For sale and sold separately are these ISOfix brackets for standard or msport seats.
They are bolt on components and replace the none ISOfix bracket.
To fit, it will be necessary to remove the base of the seat. You may or may not need to remove the back of the seat but I find this easier to do for access and reassembly.
Collection from Coventry
Can post at buyers additional expense and risk
Not seen any for sale with a published price against them.
£50 each and that includes the delivery which will be either evri or inpost.
Evri I will need your address
Inpost I will need your chosen locker location, your email and mobile number.
Bank transfer or PayPal is accepted and buyer pays any fees.
Yes, straight forward.
1st remove the back of the seat. T40. Behind the removable covers on Msport and force the leather out the way on standard seats.
Disconnect heating element if fitted, lift back off being mindful of heater wiring route.
Set seat to it's lowest point if fitted with thigh support and have the base at highest level.
All this must be set prio to removing electric bases from the car.
Removed 2 T30s either side in end of horizontal bar.
Use pry tool to prise brackets off end of bar.
Lift and thump rearward to dislocate hooks with little plastic translucent covers on.
Prise plastic strip off from across bar and rear of seat.
Disconnect any electrics from yellow connector heated if fitted and occupancy sensor.
Lift off base.
Removed t15 I think from plastic trim at rear and unclip to access 2 of the 4 T30.
Removed 4 T30 holding the the standard bar.
I find fitting the isofix bar to the seat base and getting the isofix brackets through the holes in the leather and locating the 4 spring hooks or equivalent on Msport bases easier to do prior to bolting the bracket back on to the base.
The tricky bit, until you've got the technique nailed, is getting the hooks on the base back under the lugs, then pry the brackets back on and reassemble the rest.
There is a good thread on here that I've seen.
Is should show up if you search the word squab.
I've found I'm quite adept at seats.
You need to have made 5 posts to send a DM. Hover over the names of the person you want to send it to and there will be a tab for "send direct message".
