e85 & e86 headlights, same dimension?
im looking to replace my e85 headlights with e86 headlights. i like how the e86 headlights are clear without the yellow turn signals.
are they both the same in dimension? will it fit flush if i were to switch it up?
E85 are roadsters, E86 are coupes.
All the same dimensions. However, facelift cars (2006 onwards) have different xenon units :thumbsup:
The difference with facelift is the flash to pass is with the outer lens, where as the prefacelift uses the inner bulb, you will need to replace LCM or if you have sat nav and Intravee then turn on this feature.
Sent from my iPhone 5 using Tapatalk pro
Go for the s.steel headlights !
Best looking oem headlights on both E85 , E86 !
