E85 Convertable, Drivers window not working properly
Tilltothemax
New member
Hey everyone. I've got an e85 convertable z4 and the drivers side window only some times goes back up, no issues with the other window. I've tested the switch and the regulator and they both work, theres nothing blocking the pass of the window, the cables fully in tact. I replaced the relay in the gm5 and it worked a few times then stopped going back up again. It goes down fine, just going up it has trouble occasionally. It also doesnt lower when I open/close the door. I'd be happy for a way to override the current switch and just directly put power to it but If i do that I dont think the roof will go down then.
Any help or suggestions are much appreciated
Matilda :)
