E85 Coding Question
Did some searching and found this
[FH_BEIFAHRERTUER_TIPP_AUF,One-touch opening passenger's power window]
[FH_BEIFAHRERTUER_TIPP_ZU,One-touch closing passenger's power window]
to activate in your GM using ncsexpert..
Can someone confirm? Haven't used ncs in awhile, so will take some time to familiarize myself with it before going in tomorrow to get it done.
igeak691 said:
Just did it, works a treat.. thanks!
Hello is there any guides on how to make changes for example to have remote roof open follow these steps. And so on with the other things?
That's a bit of a vague question as it would depend on what software you are using to code the car. E.g. there are guides online for NCS Dummy which I use that are very good at identifying different features and how to code them. I'm sure there are plenty of guides for the other software as well. Actually, check the coding section of this site, I seem to remember much help available within.
Good luck with the coding. :thumbsup:
Nothgiel said:
Auto lock is dangerous. What if you crash off a bridge and need to get out mid air :!:
auto lock doesn’t stop you from opening the doors from the inside.
If you're crashing off a bridge you'd be safer in the car with seatbelts and airbags ! :D
quite apart from the fact that unless it was extra-ordinarily high you would only have time for fuuuu...... before you hit. No time to fart around with seat belts and opening doors! :roll: :poke:
