daveparkinson
Changed both front and back sensorsto brakes easy to do .Back is on the drivers side take off back wheel, on the mud guard there is a pocket at the bottom undo the three fixings pull down the pocket in the right corner is a plastic door undo and pull out the conector .Replace with the new conector pull out the pad sensor wheel end fit cable where old comes off push in pad sensor job done .The front is the same passenger side easer to get at no mud guard job in total took 70 minutes
