If you want to see how much further in or out they will sit you can put details in here:- https://www.willtheyfit.com/index.php?width=205&aspect=55&diameter=16&wheelwidth=6.5&offset=40&width2=235&aspect2=50&wheel_size=17&wheel_width=7-5&offset2=34
Are you fitting MV3s ? Those dimensions and sizes are identical to mine. They fit fine with only a very faint rub on the outside leading upper edge of the front wheel arch liner when going over some high speed compression bumps.
