P plowy Active member Sep 21, 2014 #1 With so many things said about stiff rear soft front on the Z surely the E46 M3 springs will fit the car and I wondered what the comparison would be if any,,thoughts...?? I have a set in the garage from my E46 M3...... Hmmmmm :wink:
B Beedub Lifer Sutton Coldfield Sep 21, 2014 #2 Rear is compatible , front is from e36 m3. Spring rates however are probably different however.
C chris Senior member Southampton Sep 21, 2014 #3 Spring rates will be that for a 1500+kg car, so would be very high (sit higher). Cant you find any springs you like for the Z4M?
P Paul46 Member Sep 22, 2014 #4 E46 rear springs will probably break with in a few months. They are so poorly made
