E46 330ci brake upgrade
Gotbadger
 Scottish Borders
If l’ve got it right the front brakes on my 2.5i can be upgraded fairly easily by using parts from a E46. Has anyone actually done this and is it worth it?
I’ve upgraded to both the 300 and the 325mm front set up, the latter being the si discs and calipers
Visually they make a big difference filling the wheels out more especially with wheels like the 108s
Performance wise I can’t say I found much difference but then I wasn’t tracking the car
The E46 330i and 330d both had the 325mm front discs if that helps you identify which parts you need.
You may well need calipers and carriers depending on your existing set up. Plus ideally protection plates. To do all this properly. Plates is hub off to change them. I’ve just been through all this on my Facelift 2.5 (N52). I think the 330 is the same brakes as the 3.0si Zed. 325 x 25mm. But check and compare setups on realoem.
The question of 'is it worth it?' Probably depends on if you think there are any weaknesses with the brakes you already have. Bigger discs won't really make the car stop any quicker - if that's your goal then would be more cost effective to buy better brake pads with more bite.
Bigger discs will dissipate heat more, so if you do track work, then yes, definitely worth it for sustained stopping power. On the road in everyday driving, probably not worth it.
Bigger discs do look better too, if that's important.
Having gone from that 2.5i to a 3.0si with bigger brakes I don't really notice much difference in them - albeit neither were running particularly good pads. The 3.0si was dire when I first got it, chucking a set of Mintex pads on the front made a good difference (went from "will it stop?" to "it stops kinda well".)
(The discs/pads on the 2.5i are on the cheaper end of the market, whole set was £90 from memory to get through MOT. Believe it or not they improved the braking though!)
Seems like it’s all feasible then.
Not only feasible, but a relatively easy DIY job. The only difficulty you are likely to encounter is if you round out the grub screws that secure the discs. Then you are into a world of pain that might involve replacing the hubs too. The harder part, if upgrading to Si (325mm) spec, is locating caliper carriers at a good price. Unlike discs and calipers (I have a decent pair available :-)) , they are hard to come by.
Regardless of whether they make a difference to braking performance, I do think it’s one of the few mods you can do that actually adds value to a Z4.
If it wets your appetite some pictures of mine before and after…
This is 286x22 - 325x25 3.0si. BMW drilled discs, calipers, carriers, plates, hubs etc etc. £££
Bigger discs do help with stopping as you have more leverage.
As a cheaper and easier alternative I have some brand new upgraded 300mm EBC discs and pads from a 3.0 available, I can throw in some used 3.0 caliper carriers ( the calipers are the same) so they fit straight on your 2.5i
