E 89 settings
TONYMOR
Hi all very recently changed from E 85 roadster to E 89 2.31 . Love it .
Does anyone know how to increase the number of indicator flashes on the flick option and also can the volume be uppted on the parking sensors ?.
Advice needed.
Do you have idrive or not?
I can do it on idrive in the vehicle settings.....however don't know how to if you don't have nav
No don't have I drive guess I need to take a science degree then study the handbook .
Life was a lot easier with the E 85!!!.
Number of indicator flashes is either 1 or 3 - adjusted via the buttons on the indicator stalk when the engine is running ... you really will have to read the instructions I'm afraid ! You just get into a menu, then a sub menu displayed where the odometer is on the dash and pick what you want.
Beeping - no way of changing volume that I know of.
Having come from a 330d LCI with idrive I found the E89 without it a bit tedious. Once set up though it is not something you revisit.
