mac27040 said:
Xenon isn’t just low beam, on prefacelift models xenon is low beam and high beam, halogen is flash to pass. On facelight the xenon does low & high beam and flash to pass.
Guess the pin 8 is for the xenon shutter motor
hello mac!
thabks for all
today, i mounted my bixenon
I have a 3.0i prestyled and i mounted bixenon restyled
PRE-FACELFT WIRING
1. RAIN SENSOR
2. LOW BEAM
3. HIGH BEAM
4. SIDE LIGHT
5. HAZARD
6. HAZARD
7. INDICATOR
8. BI XENON or empty if you have halogen
FACE LIFT
1. RAIN SENSOR
2. LOW BEAM
3. SIDE LIGHT
4.
5. HAZARD
6. HAZARD
7. INDICATOR
8. BI XENON
its very easy, you move i your connector: pin4 to pin3, and the pin 3 to pin 8. pin 4 is finally empty
If you have a xenon prestyled, move pin 8 to pin4, this pin its empy.
With NCS expert coding your FA or V.O $522 for xenon, and sg codieren from ALSZ/LZM
The next coding in your ALSZ:
CC_STANDLICHT_RECHTS nicht_aktiv Check Control (CC) - parking lights - right
CC_STANDLICHT_LINKS nicht_aktiv Check Control (CC) - parking lights - left
WARMUEBERWACHUNG_SL_LI nicht_aktiv Hot monitoring - parking lights – left
WARMUEBERWACHUNG_SL_RE nicht_aktiv Hot monitoring - parking lights – right
KALTUEBERWACHUNG_SL_LI nicht_aktiv Cold monitoring - parking lights – left
KALTUEBERWACHUNG_SL_RE nicht_aktiv Cold monitoring - parking lights – right
KALTUEBERWACHUNG_FL nicht_aktiv Cold monitoring - high beams
WARMUEBERWACHUNG_FL nicht_aktiv Hot monitoring - high beams
Rear if you change lights restyled led:
PWM_ANSTEUERUNG_SL_RE_HI = Change to 01 (Default 02)
PWM_ANSTEUERUNG_SL_LI_HI = Change to 01 (Default 02)
BREMSLICHT_ALS_STANDLICHT = Change to Not Active (Default Active)
To avoid the error of height levelers, if you have only put the headlights, and have not retrofitted them
LEUCHTWEITENREG_AUTOM - nicht_aktiv
LEUCHTWEITENREG_DYNAM - nicht_aktiv
