Hi
Long time reader, first time poster.
I recently got the dreaded three lights on my dash (E86 3.0si Coupe). I had the codes read at my local garage and (after clearing some old codes) the problem seems to be "5E30 DSC sensor, lateral acceleration, plausibility". Tha garage advised that a new DSC sensor (or "Yaw sensor") would be required. BMW want nearly £500 for the part (part #34526769174). I have found refurbished parts for between £250 and £350.
I have a couple of questions and would really appreciate any help:
1. Does anyone know if these parts need recalibrating following fitting or are they just plug and play? If yes, can this easily be done via INPA?
2. Does anyone know if other BMW yaw sensors (i.e. different part numbers) would be compatible with the E86 (older E85s use a slightly different part which can be found for around £50)?
Thanks in advance!
Sam
Thanks in advance!
Sam
