Ok so my car went to BMW today after the ABS/DSC and handbrake lights came on! I have now been told that there is a fault with the DSC Control Unit and needs replacing. I know this is a classic fault having read the forum and there are many posts on the forum. I've been hit with a £1,300 bill to replace the DSC control unit. My question is, is the DSC Control Unit the same as the ABS Control Unit? I've been told there is a company called Ecutesting.com that will rebuild your pump and Ecu/module and send it back to you with a lifetime warranty for £195.
http://www.ecutesting.com/catalogue/pro ... 16203.html
A bit of clarification on the subject would be greatly appreciated as I'm a bit confused.
On another point my speedometer is not working, is this related to the control unit and by replacing my control unit does anyone know if this will fix the speedo problem, maybe through your own experience.
I have a 2.5i 2007 Z4.
Any help appreciated
