Drivers window needs adjusting?
Hazwaz7
Hey everyone
Since I got my Zed I have noticed that the drivers side window is just a tad lower than the passenger side when the doors are shut and windows up
No water gets in but it is a lot noises on the drivers side when on the motorway
It needs to be adjusted slightly and raised, can anybody tell me how easy this is to do?
I had a search through the forums but to no avail
Thanks!
Sounds like your car isn't auto upping the last few mm to make the seal so try this
1 )Ignition on car not running
2 )Hold both windows to fully down & keep held a couple of seconds
3 ) Hold both windows to fully up again keeping them held a couple of seconds
Igntion off then start car & try opening & shutting whilst window is up , it should auto drop & up a little
This is the hardware adjustment procedure for the windows (and it is quite difficult, but must be done for example when the window mechanism is replaced):
page 1
http://workshop-manuals.com/bmw/z_series_e85/z4_3.0i_m54_roadst/2_repair_instructions/51__body_equipment_%28roadst%29/33__front_electrically_operated_windows/1_ra__adjusting_left_or_right_front_door_window_glass/
page 2
http://workshop-manuals.com/bmw/z_series_e85/z4_3.0i_m54_roadst/2_repair_instructions/51__body_equipment_%28roadst%29/33__front_electrically_operated_windows/1_ra__adjusting_left_or_right_front_door_window_glass/page_1679/
page 3
http://workshop-manuals.com/bmw/z_series_e85/z4_3.0i_m54_roadst/2_repair_instructions/51__body_equipment_%28roadst%29/33__front_electrically_operated_windows/1_ra__adjusting_left_or_right_front_door_window_glass/page_1680/
The software reset procedure has a little bit more features than mr wilks displays, as there is a seperate erasure procedure and a reinitialisation procedure :
page 1:
http://workshop-manuals.com/bmw/z_series_e85/z4_3.0i_m54_roadst/2_repair_instructions/67__electrical_drives/62__drive_window_regulator/2_ra__notes_on_initializing_power_window_unit_%28from_04_2004%29/
page 2:
http://workshop-manuals.com/bmw/z_series_e85/z4_3.0i_m54_roadst/2_repair_instructions/67__electrical_drives/62__drive_window_regulator/2_ra__notes_on_initializing_power_window_unit_%28from_04_2004%29/page_2426/
If the software reset and reinitialisation doesnt work, you have to do the hardware adjustments.
Brilliant, I will give it a go thank you
page 1
page 2
page 3
page 1:
page 2:
Thank you. That's really useful, hopefully I will get it sorted
