The double-click window open is called 'Comfort opening'
Right checked with SSS and easy access isn't shown but managed to code it via NCSexpert
If you want to use NCSExpert then open the GM5 module and look for the following: (change nicht_aktiv to einstiegshilfe) window drops when you open door.
FUNKTIONTUERSCHLOSS - Door Lock function
nicht_aktiv
FERNBEDIENUNG_1 - Key 1
nicht_aktiv
FERNBEDIENUNG_2 - Key 2
nicht_aktiv
FERNBEDIENUNG_3 - Key 3
nicht_aktiv
FERNBEDIENUNG_4 - Key 4
nicht_aktiv
The options available are:
nicht_aktiv - Single click unlocks all doors
zv_selektiv - Single click unlocks drivers door, double click opens all doors
einstiegshilfe - Comfort opening - one click opens all doors, double click opens driver's window
Updated coding list: https://drive.google.com/file/d/0B1Hn7Wv1L2HTYXpaM1lwRlpVV1U/edit?usp=sharing
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
